15 years agode2 board minimum voltage
hi could I operate the de2 board with less then 9 volt ?
15 years agoThe programmer screenshot looks like AS programming has been succesful. In case of doubt, you are also able to verify the EPCS data. Sucessful programming doesn't imply, that the code is valid for the respective FPGA, however. But that's nothing we can help with. Did you try to run the same code through (volatile) JTAG programming?
