14 years agoDE2 Board HEX display fail to function
Hi all, there's something wrong with my de2 board.. when i push the power button, i got all lights flashing except HEX6, the most bottom segment is not functioning. It happened when I was working wit...
14 years agoDid you burn any program onto the FPGA chip? If you did, then this phenomenon may be normal. You can use the DE2_115_ControlPanel tool inside the accompanying CDROM to manipulate the HEX by yourself, so that you can verify it is working or not.
