13 years agoDE2 board and Qsys
I am looking for Qsys tutorials as they relate to my brand new DE2 board. Can anyone help me? I use winvista (32bit) Quartus 12.1 sp1.
Thanks: David Lee10 Replies
--- Quote Start --- Question? Have you tried running your programs on a windows VISTA computer? I believe this is my main problem. I use winvista32bit, and I know from researching this problem there are compatibility issues with VISTA. Thanks David Lee --- Quote End --- You're wasting your time trying to use anything but the supported operating systems: http://www.altera.com/download/os-support/oss-index.html You can keep Vista installed if you want to, but you should install VirtualBox and then install a supported operating system. I have a dozen or so VMs with versions of Quartus/Modelsim under Centos(RedHat)/WinXP/Win7 that I use when confirming scripts and tutorials work. Cheers, Dave - Altera_Forum
Hi David,
I can confirm that Quartus 11.1sp1 should work Ok, but that 12.1sp1 is broken (due to Altera's changes in their generated scripts). Please follow the sequence below for Quartus 11.1sp1 and let me know if you still have trouble. Cheers, DaveJTAG-to-Avalon-MM Tutorial on the DE2 ------------------------------------- 4/8/2013 D. W. Hawkins ([email protected]) The tutorial was written using Quartus II 11.1sp1. The following test was performed using 11.1sp2. ------------------------------------------------------------------------------- Quartus II 11.1sp2 - Synthesis+Simulation Build Procedure --------------------------------------------------------- 1. Download the zip file from the Altera Wiki http://www.alterawiki.com/wiki/Using_the_USB-Blaster_as_an_SOPC/Qsys_Avalon-MM_master_Tutorial Save as c:/temp/altera_jtag_to_avalon_mm_tutorial.zip 2. Unzip it 3. Start Quartus II 11.1sp2 I used a VirtualBox VM with Windows-XP and Quartus 11.1sp2 for this test. 4. Select the Tcl console 5. Change directory to the Qsys build tcl> cd {C:\temp\altera_jtag_to_avalon_mm_tutorial\hdl\boards\de2\qsys_system} 6. Source the synthesis script tcl> source scripts/synth.tcl The output is Synthesizing the DE2 'qsys_system' design ----------------------------------------- - Quartus Version 11.1 Build 259 01/25/2012 Service Pack 2 SJ Full Version - Creating the Quartus work directory * C:/Temp/altera_jtag_to_avalon_mm_tutorial/hdl/boards/de2/qsys_system/qwork - Create the project 'de2' * create a new de2 project - Check the Qsys system * Copying the Qsys system file to the build directory * Please run Qsys, click on the 'Generation' tab, select 'Verilog' for 'Create simulation model', and click the 'Generate' button to generate the Qsys system, and then re-run this script Per the instruction, run Qsys, open qsys_system.qsys, and click on the generate tab. Change the "Create Simulation Model" pull-down menu to create the Verilog simulation directory, i.e., the folder qwork/qsys_system/simulation once things are generated. Click the "Generate" button to generate the system Re-run the script by sourcing it again tcl> source scripts/synth.tcl The output is Synthesizing the DE2 'qsys_system' design ----------------------------------------- - Quartus Version 11.1 Build 259 01/25/2012 Service Pack 2 SJ Full Version - Create the project 'de2' * close the project * open the existing de2 project - Check the Qsys system - Creating the design files list - Applying constraints - Processing the design - Processing completed This confirms that the project synthesizes correctly under Quartus II 11.1sp2. 7. Start Modelsim Modelsim-ASE 10.0c was used for this test (the version used by Quartus 11.1sp2) 8. Change directory per the instructions in the tutorial PDF, which in my case was Modelsim> cd {C:\temp\altera_jtag_to_avalon_mm_tutorial\hdl\qsys_system} 10. Edit the simulation script Since this project is using the DE2 board, not the BeMicro-SDK, edit the script in scripts/sim.tcl to change the board name from bemicro_sdk to de2 i.e., change the line set board $hdl/boards/bemicro_sdk to set board $hdl/boards/de2 11. Run the simulation script Modelsim> source scripts/sim.tcl The script ends with the message: # JTAG-to-Avalon-MM tutorial testbench procedures # ----------------------------------------------- # # qsys_system_bfm_master_tb - run the Avalon-MM BFM testbench # qsys_system_jtag_master_tb - run the JTAG-to-Avalon-MM testbench Type in one of these procedures (copy-and-paste it to the console) to run the two testbenches described in the tutorial PDF. For example Modelsim> qsys_system_bfm_master_tb ... lots of messages from Modelsim ... and then messages from the testbench # =============================================================== # JTAG-to-Avalon-MM SOPC System Testbench (using the BFM master) # =============================================================== # # 0: verbosity_pkg.set_verbosity: Setting Verbosity level=4 (VERBOSITY_INFO) # * Deassert reset # # ----------------------------------------------- # 1: Test the LEDs. # ----------------------------------------------- # * Write 0xAA to the LEDs # - LED register value = aah # - LED port value = aah # * Walking 1's test # - LED port value = 01h # - LED port value = 02h # - LED port value = 04h # - LED port value = 08h # - LED port value = 10h # - LED port value = 20h # - LED port value = 40h # - LED port value = 80h # # ----------------------------------------------- # 2: Test the push buttons. # ----------------------------------------------- # * Push button value = 55h # * Walking 1's test # - Push button value = 01h # - Push button value = 02h # - Push button value = 04h # - Push button value = 08h # - Push button value = 10h # - Push button value = 20h # - Push button value = 40h # - Push button value = 80h # # ----------------------------------------------- # 3: Test the on-chip RAM. # ----------------------------------------------- # * Fill 1024 locations of RAM with an incrementing count # * Read and check the RAM # # =============================================== # Simulation complete. # =============================================== # and then try the other testbench Modelsim> qsys_system_jtag_master_tb ... lots of messages from Modelsim ... and then messages from the testbench (this simulation takes a *lot* longer to run, since the testbench commands need to be serialized over JTAG) # =============================================================== # JTAG-to-Avalon-MM Qsys System Testbench (using the JTAG master) # =============================================================== # # * Reset the JTAG controller # * Deassert reset # # ----------------------------------------------- # 1: Test the JTAG protocol special character codes. # ----------------------------------------------- # * Check the JTAG-to-Avalon-ST special codes encode/decode as data: 4a4dh # * Check the bytes-to-packets special codes encode/decode as data: 7a7b7c7dh # # ----------------------------------------------- # 2: Test the LEDs. # ----------------------------------------------- # * Write 0xAA to the LEDs # - LED register value = aah # - LED port value = aah # * Walking 1's test # - LED port value = 01h # - LED port value = 02h # - LED port value = 04h # - LED port value = 08h # - LED port value = 10h # - LED port value = 20h # - LED port value = 40h # - LED port value = 80h # # ----------------------------------------------- # 3: Test the push buttons. # ----------------------------------------------- # * Push button value = 55h # * Walking 1's test # - Push button value = 01h # - Push button value = 02h # - Push button value = 04h # - Push button value = 08h # - Push button value = 10h # - Push button value = 20h # - Push button value = 40h # - Push button value = 80h # # ----------------------------------------------- # 4: Test the on-chip RAM. # ----------------------------------------------- # * Fill 32 locations of RAM with an incrementing count # * Read and check the RAM # # =============================================== # Simulation complete. # =============================================== # This confirms that the project simulates correctly under Quartus II 11.1sp2 with Modelsim-ASE 10.0c. - Altera_Forum
--- Quote Start --- Perhaps you could send me your completed synthesized project file, it should be around 1MB or so, and could try running that. --- Quote End --- Sure, I'll download the zip file and go through each step to confirm it works. I'll upload the project file shortly. Cheers, Dave - Altera_Forum
Feedback for Altera JTAG-to-Avalon-MM Tutorial
I am now using Quartus II 11.1 sp1 with winvista32bit.date: 4/8/13 I have gone through this tutorial several times now to make sure I get it right. After the program synthesized I received the same error message “Synthesis not successful (4 errors)”. The two errors are below. In file: sopc_system_bfm_master_tb.sv Error (10161): Verilog HDL error at sopc_system_bfm_master_tb.sv(53): object "verbosity_pkg" is not declared Error (10161): Verilog HDL error at sopc_system_bfm_master_tb.sv(54): object "avalon_mm_pkg" is not declared Question? Can you tell me how to resolve these errors? Perhaps you could send me your completed synthesized project file, it should be around 1MB or so, and could try running that. Thanks David Lee - Altera_Forum
Yes, I will do that. Thanks for your help. David Lee
Hi David,
Thanks for the feedback on the tutorial. Unfortunately Altera change how their Qsys tool works between versions. The tutorial was written and testing using 11.1sp1. I'll take a look at updating it for 12.1sp1, but I'm a little busy at the moment. Its possible to have multiple versions of Quartus installed. I recommend installing 11.1sp1 so that you can get things working correctly, and then you will understand how the tool works. There is a synthesis script that will automatically compile everything. You could start with that under 11.1sp1 to get a "built" design, and then work your way backwards to see what files etc that project included. This will be a good learning experience for you and will help you become comfortable with the tools. Cheers, Dave - Altera_Forum
Note: My board is the DE2 (no# ) board from ALTERA I am using Quartus II 12.1 sp1with winvista32bit. 1. Under 3.1 Project Creation > Add files: it does not say specifically which files to add it just has [page 2 of 5]. I tried several variations. 2. Under 3.1 SOPC Builder Component (page 8) > bottom paragraph: These files… were not found in the project directory. Instead they were in C:\altera\quartus\bin a. bfm_master.v, b. jtag_master.v c. led_pio.v d. button_pio.v e. onchip_ram.v f. sopc_system.v 3. Under 3.4 Synthesis first paragraph the file sopc_system.qip was found in C:\altera\quartus\bin. Also in this same paragraph the end statement says “press the play button on the GUI.” Could not find the “play button” so I assumed you meant the Start Compilation button so I pressed that. Here are the results: failed to compile Error (10161): Verilog HDL error at sopc_system_bfm_master_tb.sv(53): object "verbosity_pkg" is not declared Error (10161): Verilog HDL error at sopc_system_bfm_master_tb.sv(54): object "avalon_mm_pkg" is not declared Error: Quartus II 32-bit Analysis & Synthesis was unsuccessful. 2 errors, 0 warnings a. Error: Peak virtual memory: 323 megabytes THANKS: David Lee - Altera_Forum
Thank You, I will look into it ASAP. David Lee
Terasic normally ship the board with "My First NIOS II Tutorial" and PDFs like that.
The University Program site has additional tutorials: http://www.altera.com/education/univ/software/unv-software.html Click on the links on the left of that page, eg., Digital Logic. and here's one I wrote and posted on the wiki: http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial There are several versions of the DE2 board; DE2, DE2-70, DE2-115. The tutorial just has the original DE2 board in there, but it'll be enough for you to get to grips with the tools. Cheers, Dave
