13 years agoDE2 board and Qsys
I am looking for Qsys tutorials as they relate to my brand new DE2 board. Can anyone help me? I use winvista (32bit) Quartus 12.1 sp1. Thanks: David Lee
13 years agoHi David,
I can confirm that Quartus 11.1sp1 should work Ok, but that 12.1sp1 is broken (due to Altera's changes in their generated scripts). Please follow the sequence below for Quartus 11.1sp1 and let me know if you still have trouble. Cheers, Dave
JTAG-to-Avalon-MM Tutorial on the DE2
4/8/2013 D. W. Hawkins ([email protected])
The tutorial was written using Quartus II 11.1sp1. The following test was performed
using 11.1sp2.
Quartus II 11.1sp2 - Synthesis+Simulation Build Procedure
1. Download the zip file from the Altera Wiki
http://www.alterawiki.com/wiki/Using_the_USB-Blaster_as_an_SOPC/Qsys_Avalon-MM_master_Tutorial
Save as c:/temp/altera_jtag_to_avalon_mm_tutorial.zip
2. Unzip it
3. Start Quartus II 11.1sp2
I used a VirtualBox VM with Windows-XP and Quartus 11.1sp2
for this test.
4. Select the Tcl console
5. Change directory to the Qsys build
tcl> cd {C:\temp\altera_jtag_to_avalon_mm_tutorial\hdl\boards\de2\qsys_system}
6. Source the synthesis script
tcl> source scripts/synth.tcl
The output is
Synthesizing the DE2 'qsys_system' design
- Quartus Version 11.1 Build 259 01/25/2012 Service Pack 2 SJ Full Version
- Creating the Quartus work directory
* C:/Temp/altera_jtag_to_avalon_mm_tutorial/hdl/boards/de2/qsys_system/qwork
- Create the project 'de2'
* create a new de2 project
- Check the Qsys system
* Copying the Qsys system file to the build directory
* Please run Qsys, click on the 'Generation' tab, select 'Verilog'
for 'Create simulation model', and click the 'Generate' button
to generate the Qsys system, and then re-run this script
Per the instruction, run Qsys, open qsys_system.qsys, and click on the generate tab.
Change the "Create Simulation Model" pull-down menu to create the Verilog simulation
directory, i.e., the folder qwork/qsys_system/simulation once things are generated.
Click the "Generate" button to generate the system
Re-run the script by sourcing it again
The output is
* close the project
* open the existing de2 project
- Creating the design files list
- Applying constraints
- Processing the design
- Processing completed
This confirms that the project synthesizes correctly under Quartus II 11.1sp2.
7. Start Modelsim
Modelsim-ASE 10.0c was used for this test (the version used by Quartus 11.1sp2)
8. Change directory per the instructions in the tutorial PDF, which in my case was
Modelsim> cd {C:\temp\altera_jtag_to_avalon_mm_tutorial\hdl\qsys_system}
10. Edit the simulation script
Since this project is using the DE2 board, not the BeMicro-SDK, edit the
script in scripts/sim.tcl to change the board name from bemicro_sdk to de2
i.e., change the line
set board $hdl/boards/bemicro_sdk
to
set board $hdl/boards/de2
11. Run the simulation script
Modelsim> source scripts/sim.tcl
The script ends with the message:
# JTAG-to-Avalon-MM tutorial testbench procedures
# qsys_system_bfm_master_tb - run the Avalon-MM BFM testbench
# qsys_system_jtag_master_tb - run the JTAG-to-Avalon-MM testbench
Type in one of these procedures (copy-and-paste it to the console) to run
the two testbenches described in the tutorial PDF.
For example
Modelsim> qsys_system_bfm_master_tb
... lots of messages from Modelsim ... and then messages from the testbench
# JTAG-to-Avalon-MM SOPC System Testbench (using the BFM master)
# 0: verbosity_pkg.set_verbosity: Setting Verbosity level=4 (VERBOSITY_INFO)
# * Deassert reset
# 1: Test the LEDs.
# * Write 0xAA to the LEDs
# - LED register value = aah
# - LED port value = aah
# * Walking 1's test
# - LED port value = 01h
# - LED port value = 02h
# - LED port value = 04h
# - LED port value = 08h
# - LED port value = 10h
# - LED port value = 20h
# - LED port value = 40h
# - LED port value = 80h
# 2: Test the push buttons.
# * Push button value = 55h
# - Push button value = 01h
# - Push button value = 02h
# - Push button value = 04h
# - Push button value = 08h
# - Push button value = 10h
# - Push button value = 20h
# - Push button value = 40h
# - Push button value = 80h
# 3: Test the on-chip RAM.
# * Fill 1024 locations of RAM with an incrementing count
# * Read and check the RAM
# Simulation complete.
and then try the other testbench
Modelsim> qsys_system_jtag_master_tb
(this simulation takes a *lot* longer to run, since the testbench commands
need to be serialized over JTAG)
# JTAG-to-Avalon-MM Qsys System Testbench (using the JTAG master)
# * Reset the JTAG controller
# * Deassert reset
# 1: Test the JTAG protocol special character codes.
# * Check the JTAG-to-Avalon-ST special codes encode/decode as data: 4a4dh
# * Check the bytes-to-packets special codes encode/decode as data: 7a7b7c7dh
# 2: Test the LEDs.
# 3: Test the push buttons.
# 4: Test the on-chip RAM.
# * Fill 32 locations of RAM with an incrementing count
This confirms that the project simulates correctly under Quartus II 11.1sp2
with Modelsim-ASE 10.0c.
