13 years agoDE2 board and Qsys
I am looking for Qsys tutorials as they relate to my brand new DE2 board. Can anyone help me? I use winvista (32bit) Quartus 12.1 sp1. Thanks: David Lee
13 years agoFeedback for Altera JTAG-to-Avalon-MM Tutorial
Note: My board is the DE2 (no# ) board from ALTERA I am using Quartus II 12.1 sp1with winvista32bit. 1. Under 3.1 Project Creation > Add files: it does not say specifically which files to add it just has [page 2 of 5]. I tried several variations. 2. Under 3.1 SOPC Builder Component (page 8) > bottom paragraph: These files… were not found in the project directory. Instead they were in C:\altera\quartus\bin a. bfm_master.v, b. jtag_master.v c. led_pio.v d. button_pio.v e. onchip_ram.v f. sopc_system.v 3. Under 3.4 Synthesis first paragraph the file sopc_system.qip was found in C:\altera\quartus\bin. Also in this same paragraph the end statement says “press the play button on the GUI.” Could not find the “play button” so I assumed you meant the Start Compilation button so I pressed that. Here are the results: failed to compile Error (10161): Verilog HDL error at sopc_system_bfm_master_tb.sv(53): object "verbosity_pkg" is not declared Error (10161): Verilog HDL error at sopc_system_bfm_master_tb.sv(54): object "avalon_mm_pkg" is not declared Error: Quartus II 32-bit Analysis & Synthesis was unsuccessful. 2 errors, 0 warnings a. Error: Peak virtual memory: 323 megabytes THANKS: David Lee
