16 years agoDE2 Audio Codec Programming
Hi, I am engg student.I are working on SOPC baesd speech to text conversion.I am confused with how to to program audio codec for Audio to Digital conversion for input from microphone and give it...
16 years ago --- Quote Start --- Hello Mr. Khan, you could use one of the PLLs on the Cyclone II chip to convert from 50MHz to 24MHz. Or you could just implement a simple counter. You could just divide by 2 (giving 25MHz). This would result in a sampling rate slightly more than 48KHz, but depending on your application would probably not make an audible difference. --- Quote End --- Dear sir i have done the intitialization of the codec registor by using the 50Mhz crystal i am getting ack , sir i am not getting whether xclk i.e the master clock of codec must require to fetch the data from LR chanal please sugest the logic for sound fetching & more about the DSP mode of codec.
