10 years agoDE2-115 PLL dynamic phase doesn't work at low output frequencies?
We use the ALTPLL MegaWizard Plug-in Manager to build the PLL module. We use this PLL module to generate two same frequency output clock. Then, We use the PLL dynamic phase shifting function to adjus...
10 years agoHi Galfonz,
Thank you very much for your reply. It is very much appreciated! I am a very beginner in FPGA. 1. Could you explain more about " if it is the output frequency itself, or the ratio of input/output frequencies." 2. When you say the low frequency might max out the PLL's register, is there anyway to check whether the low frequency max out the register? Thanks a lot again. Looking forwards to your reply.
