10 years agoDE2-115 PLL dynamic phase doesn't work at low output frequencies?
We use the ALTPLL MegaWizard Plug-in Manager to build the PLL module. We use this PLL module to generate two same frequency output clock. Then, We use the PLL dynamic phase shifting function to adjus...
10 years agoIt would be interesting to find out if it is the output frequency itself, or the ratio of input/output frequencies. With lower frequencies you may be maxing out the PLL's registers.
