15 years agoDE2 - video to VGA in VHDL
hello, Important point to understand my concerns, I am European (vhdl and pal). I am using a DE2 board and I wanted to start transferring the video input to VGA output. For this I used the ...
12 years agoHave you solved the prolem? do you have vhdl code for DE2 that configures the board for PAL in VGA out?
Thanks, pzorea. --- Quote Start --- hello, Important point to understand my concerns, I am European (vhdl and pal). I am using a DE2 board and I wanted to start transferring the video input to VGA output. For this I used the program DE2_TV cdrom. But I get nothing out! In fact I get a picture in case I go back to NTSC but the image contains only saturated RGB colors, very ugly ! I was not able to measure the frequency on pin 14 of the VGA :oops: In addition, the codes are in verilog and I usually work in vhdl. In a second step I decided to use DE2_Default (work on an image to start) included on the CDROM, but I do not know how to get from an image file. Hex? and the code is still in verilog ... My questions: Is there a version of vhdl DE2_TV and works in PAL and can you explain the behaviors and problems I encounter? Why the project is there no file VGA_Param.h when he is in DE2_Default ? Maybe he should copy the folder VGA_controller? Is there a program to convert an image in hex​​ ? Where is the documentation of his examples ? And do you know if there is a version of vhdl examples? If there are no equivalent programs in vhdl I can include my code in vhdl in the original project in verilog? Can you tell me how (the method) and where in the verilog code I have to do :confused: I wish the final apply filters on a simple image you links to examples of this type with the DE2 board and vhdl ? Thank you in advance for your answers. nv --- Quote End ---
