8 years agoDE10 pins not found
Hello, I'm trying to build my first DE10 Nano design, and getting some critical fitter warnings that make no sense to me. Specifically, I get the "warning" that, "Some pins have incomplete I/O...
8 years agoIf your design doesn't use the DDR3 IP, you can ignore these warnings. Even when I did a sample design with just simple logic, the fitter would spit out warnings that some DIFF IO pins are not assigned,but the compilation and other processes would go on successfully.
Just make sure that all of the other processes do not have any errors and that the final stages are all clear. You can ignore these if you're not using them in the design.
