DE1-SOC Simulation Model Generation Failed on MegaWizard
- 4 years ago
Hello again,
@ShengN_Intel thank you for your support to solve my problem. I've solved the problem by changing the character group. When compiling the projects or IP cores, Quartus tries to compile with system language. Anyone facing this problem in future can change the character set and solve the problem. We can mark the topic as solved.
Hello again,
Thank you for your answer. I don't need the simulation file generation for this study. Just I'm applying the steps shown in the getting started guide. How can I disable the simulation file generation?
And yes, I say the two slashed at the report but I couldn't find the reason for that. In each version of Quartus, it's the same, the path after the Quartus folder has two slashes. Also, how can I correct this path? I've checked for the windows path environment but there's no slash there.
You are following this manual http://www.ee.ic.ac.uk/pcheung/teaching/E2_experiment/My_First_Fpga.pdf right?
I notice that you use Quartus v17.0 for the steps. Make sure to use Quartus v13.1 instead.
