akdrs
4 years agoDE1-SOC Simulation Model Generation Failed on MegaWizard
I'm trying to start a project with DE1-SoC and started from its own documentation.
https://fpgacloud.intel.com/devstore/platform/13.1.4/Standard/de1-soc-my-first-hps/
On the My First FPG...
- 4 years ago
Hello again,
@ShengN_Intel thank you for your support to solve my problem. I've solved the problem by changing the character group. When compiling the projects or IP cores, Quartus tries to compile with system language. Anyone facing this problem in future can change the character set and solve the problem. We can mark the topic as solved.
sstrell
4 years agoDo you need to generate simulation files for this? Make sure simulation file generation is disabled. I don't see in the project you linked to where this instruction is to generate this, but maybe I'm missing something.
Also, for some reason there are two slashes (//) in the middle of your path. Not sure if that has anything to do with the issue.
