9 years agoDE1-SoC problem with tree please HELP!!
I’m trying to configure a qsys system with hps and vga control to see the Linux environment and create a c program that can obtain the memory mapped signal and print on the vga. The steps that I d...
9 years agoI add a *dtb file in txt format generated by the command
sopc2dts -i sistema.sopcinfo -b soc_system_board_info.xml -b hps_common_board_info.xml -o socfpga.dts --bridge-remova
l all --clocks. You can check that is there a VIP declaration.
