9 years agode1-soc ethernet ip
Hey guys! :) In the project I'm developing, I need a TCP/IP connection among the board and a PC. The PC will work as a client and the board will be responsible to send the data to the PC (we wa...
9 years ago --- Quote Start --- I assume you are talking about the Ethernet that is part of the DE1-SoC HPS portion. If so, the Ethernet MAC is a hard IP that is part of the HPS - thus you don't have to use any soft IP to instantiate it. If you boot the DE1-SoC using the provided Linux SD image, you will find the Ethernet already usable :) That is, unless you are referring to the bare metal drivers for the Ethernet... which is a different story all together --- Quote End --- Hy sunshine, we are working on a similar project on the university. We want to stream data of the THDB-ADA Board via Ethernet to MATLAB, but we have one problem we don't know how to go on. Did you create an IP (Intellectual Property) for Ethernet in QSYS or did you run the programm with LINUX? Thanks, Chris
