9 years agode1-soc ethernet ip
Hey guys! :) In the project I'm developing, I need a TCP/IP connection among the board and a PC. The PC will work as a client and the board will be responsible to send the data to the PC (we wa...
9 years agoI assume you are talking about the Ethernet that is part of the DE1-SoC HPS portion. If so, the Ethernet MAC is a hard IP that is part of the HPS - thus you don't have to use any soft IP to instantiate it. If you boot the DE1-SoC using the provided Linux SD image, you will find the Ethernet already usable :)
That is, unless you are referring to the bare metal drivers for the Ethernet... which is a different story all together- WKhad16 years ago
[bare metal drivers for Ethernet]!!
I'm working on a project in which i need to transfer data from the sdram of the hps to the pc through the Ethernet. knowing that i have developped a bare metal c program to get the data from the FPGA to the SDRAM and perform the data treatement. now i need drivers for Ethernet for a bare metal project.
do you have any example for that?
Thanks in advance
