16 years agoDE1 Control Panel
Is there an option to download the DE1 control panel .exe files from the website?
8 years ago --- Quote Start --- The HEX display segment drivers on the DE1 card are ACTIVE LO, so driving out a '0' (low) turns the segment ON, and driving out a '1' (high) turns the segment off. The 74246 block you have in your schematic drives its outputs LO when it wants to light a segment, so that would mean the inverters you have on each output line are the source of the issue. --- Quote End --- so output on seven segment is it true? based on vector waveform i got segment b and segment c status High or logic 1
