16 years agoDE1 Control Panel
Is there an option to download the DE1 control panel .exe files from the website?
8 years ago --- Quote Start --- https://alteraforum.com/forum/attachment.php?attachmentid=14569&stc=1 this block schematic when i program and test input using switch and output using seven segment.. when i represent 1 number convert to bcd will be 0000 but seven segment as output not represent 1. Seven segment to be a=1,b=0,c=0, d=1,e=1,f=1,g=1 i want result a=0,b=1,c=1,d=0,e=0,f=0,g=0 what wrong with my seven segment --- Quote End --- The HEX display segment drivers on the DE1 card are ACTIVE LO, so driving out a '0' (low) turns the segment ON, and driving out a '1' (high) turns the segment off. The 74246 block you have in your schematic drives its outputs LO when it wants to light a segment, so that would mean the inverters you have on each output line are the source of the issue.
