12 years agode0 nano to measure temperature of a liquid, greetings from Colombia
Hello
I need help with the following project Temperature Control - Should survey the temperature of a heat emitting system. - The temperature signal must be connected to one of the ports A / D of nano-DE0 - The Deo-nano must control a fan that reduces temperature heat emitting system - In 2 7 Segment displays (or LCD display) should displaying the temperature value. - Through the switches (or external keyboard) should set the desired temperature. - To observe the desired temperature and the actual temperature of system must press a button to select the temperature to observe. Thermocouple what can I use? ideas, suggestions perdon por mi ingles, traducido por https://translate.google.com/ Gracias de antemanoNo RepliesBe the first to reply
