9 years agoDe0_nano_soc_arduino
I'm trying to run DE0-NANO SOC board with 2.8inch_Arduino tft from Terasic http://www.terasic.com/downloads/cd-rom/de0-nano-soc/, but it does not work.Please help!!!
9 years ago --- Quote Start --- Hell VLD Please be more specific on your question, "it does not work" is not a lot to go on. If you have a problem best you can do is to divide the scope in small sub-scopes and try to define measurements or strategies to determine which sub-scope is working and which is not. Best Regards, Johi. --- Quote End --- Hi Joji, and thanks for your response. I started by using de0-nano soc board (http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=205&no=941&partno=1)from Terasic. I downloaded a zip file from their site (last link (http://www.terasic.com/downloads/cd-rom/de0-nano-soc/)here), used Quartus ii 15.1 Web Edition to program the board using the .sof file, and then installed the Arduino shield on top of the board according to the Terasic instructions (see last image here (http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=205&no=941&partno=2)). Then I powered the device and turned it on. I see the backlight, but nothing else. Should I have done anything else to see some results? In particular, is there a different Quartus project file you can recommend? I just want to get started with this board and shield configuration - I don't necessarily need any specific result so far; I just want to see *something* working, and be able to make small adjustments to learn from it. Thank you.
