11 years agoDE0-Nano Ethernet add on board
Dear all I'm student of electrical engineering in university of tehran. Recently i designed an add on board for DE0-Nano board which provide it Ethernet interface. http://www.alterafo...
11 years agoDear ted,
thanks for replay. I checked MAC option about 32 bit header alignment. and test system in both situation. (select and un-select alignment in MAC option) but nothing changed! I also removed the two first byte of tx_frame in c source code. (which is used for 32 bit alignment). Again i just see that register 'aFrameCheckSequenceErrors' and 'aAlignmentErrors' increment in each send when i'm in loop back mode.
