11 years agoDE0-Nano Ethernet add on board
Dear all I'm student of electrical engineering in university of tehran. Recently i designed an add on board for DE0-Nano board which provide it Ethernet interface. http://www.alterafo...
11 years agoBriefly reviewing your Qsys/Quartus project, it all looks OK and your SignalTap does seem to be showing a packet coming in.
At this point I'm guessing there is a bug in your .c somewhere. You can double check with SignalTap that the Avalon-ST ports to/from the SGDMA are OK - they ought to be 'ready' and maybe you'll see 'sop' ? I would also suggest during this debug phase to switch over to the full 10/100/1000 MAC so you can incorporate and dump the statistics counters. If you're seeing data coming in on the PHY, and nothing on the Avalon-ST - you ought to see some counters increment.
