14 years agoDE0-Nano Control Panel connect problem
Hi, this is my first time use Altera fpga board, i copy the "DE0_Nano_ControlPanel" folder and try to run the application, it shows connection problem due to two missing file "jtag_client.dll" ...
dadin852
3 years agoI have the same problem "quartus_pgm download fail"
Because I installed two versions of Quartus, so I kept "Quartus II 13.0 (64-bit) Web Edition" only.
Then I simply reinstall Quartus II 13.0, and the problem was solved!
