14 years agoDE0-Nano Control Panel connect problem
Hi, this is my first time use Altera fpga board, i copy the "DE0_Nano_ControlPanel" folder and try to run the application, it shows connection problem due to two missing file "jtag_client.dll" ...
14 years agoI'm seeing the same problem, although I'm running Quartus 12.0sp2. Is that compatible with the DE0-Nano Control Panel?
It might also be a problem with the USB-Blaster in general as I'm not able to run nios2-configure-sof from the command line successfully either.
