9 years agoDE0-NANO Board External Clock
Hallo So i have a DE0-NANO Board, and i tried to replace the on board oscillator with a external clock. I took out the on board oscillator and connected my external clock pin to pin 3 of the on...
9 years agoAssuming your design makes use of the clock - and I assume it does given you're desire to change the clock source - then programming the "50MHz" design in, and seeing that it works, shows that your rework is good. Hence, the board is working correctly.
So, now you have good hardware, complete with new clock source, you can concentrate on the FPGA design issues. Cheers, Alex
