8 years agoDE0 board EEPROM
Hi, can anyone plz tell me how to remove a program from the EEPROM of the FPGA on the DE0 board (erase the EEPROM content). The EEPROM seems to be not configuring but having stuck with one program...
8 years agoHi raafreen,
You can try to add the configuration flash device into the programmer without using .jic file. 1.Add the FPGA device into the programmer. 2.Right click at the FPGA device, then choose Attach Flash device. 3.Select ACS device (EPCS or EPCQ on the DE0 baord). 4.Then you can turn on the erase check box which will set the factory default SFL image. Then you should be able or perform full erase on the on the EPCQ or EPCQ device on the DE0 baord. Regards, nyusof (This message was posted on behalf of Intel Corporation)
