12 years agoDDR3 UniPHY problems
I am trying to incude a DDR3 UniPHY Controller megacore to my design, but I am experiencing several issues. I am working on a TR4 development kit (TERASIC) based on the STRATIX IV FPGA (EP4SGX530KH40C2). Basically I have generated the Megacore by using the Megawizard plug-in manager, I have parametrized my DDR3 block and I have generated the entity for my design. After this I have normally instantiated the DDR3_Controller by defining it as a component inside my VHDL code, and I have connected it to the right signals. In addition I have mapped them to the pins on my development board by using the pin planner. I haven´t still developed a control logic to drive the controller but this shouldn´t be a problem. When I try to compile my design, it already fails in the Analysis and Synthesis step, and I get the following errors:Error (15700): Termination calibration block atom "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|altera_mem_if_oct_stratixiv:oct0|sd1a_0" uses RUP port, which must be connected to an I/O atom in input mode
Error (15700): Termination calibration block atom "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|altera_mem_if_oct_stratixiv:oct0|sd1a_0" uses RUP port, which must be connected to a dedicated I/O atom with no other fanout
Error (15700): Termination calibration block atom "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|altera_mem_if_oct_stratixiv:oct0|sd1a_0" uses RDN port, which must be connected to an I/O atom in input mode
Error (15700): Termination calibration block atom "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|altera_mem_if_oct_stratixiv:oct0|sd1a_0" uses RDN port, which must be connected to a dedicated I/O atom with no other fanout
Error (15853): Input port IBAR of I/O input buffer "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|SDRAM_Controller_p0:p0|SDRAM_Controller_p0_memphy:umemphy|SDRAM_Controller_p0_new_io_pads:uio_pads|SDRAM_Controller_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_ddio_3reg_stratixiv:altdq_dqs2_inst|strobe_in" must be driven by a top-level pin
Error (15065): Clock input port inclk of PLL "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|SDRAM_Controller_pll0:pll0|altpll:upll_memphy|altpll_8nd3:auto_generated|pll1" must be driven by a non-inverted input pin or another PLL, optionally through a Clock Control block
Info (15024): Input port INCLK of node "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|SDRAM_Controller_pll0:pll0|altpll:upll_memphy|altpll_8nd3:auto_generated|pll1" is not connected
Error (15856): Output port O of I/O output buffer "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|SDRAM_Controller_p0:p0|SDRAM_Controller_p0_memphy:umemphy|SDRAM_Controller_p0_new_io_pads:uio_pads|SDRAM_Controller_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_ddio_3reg_stratixiv:altdq_dqs2_inst|obuf_os_bar_0" must drive a top-level pin
Error (15856): Output port O of I/O output buffer "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|SDRAM_Controller_p0:p0|SDRAM_Controller_p0_memphy:umemphy|SDRAM_Controller_p0_new_io_pads:uio_pads|SDRAM_Controller_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_ddio_3reg_stratixiv:altdq_dqs2_inst|obuf_os_bar_0" must drive a top-level pin What is the problem here? How can I fix this? I am getting problems both by compiling the examples automatically generated by the Megacore, and the examples developed with my board are quite bugged and fully not working... BR, Giovanni.1 Reply
Hi Giovanni,
you have to launch a .tcl script to complete the constraint file for the DDR3 pins. It is something like <your_controller_name>_p0_pin_assignments.tcl hope this could solve your problem, regards,
