Alican
4 years agoDDR3 UniPHY Example Design simulation problem
I am trying to simulate my testbench based on DDR3 Example Design controller model.
Briefly; I use the DDR3 memory as dual port, under "Controller Settings" tab Number of ports:2. One of them is wr...
AdzimZM_Altera
4 years agoHi Alican,
I think that you need to check the Avalon Write protocol.
It's might be some operations that are not done yet.
Here some documents that might help you. Avalon Interface Specification , Avalon Verification IP
But it's also an option for you to use your own memory controller in your design.
If it's working well and has a good performance, then you can use it.
The failure only occurs in the simulation right and your board is working as expected?
Adzim
