12 years agoDDR3 SDRAM Qsys Sequencer
Hello, i have an Altera Cyclone V GX with Quartus 13.0 running on Windows 7 64 bit.
I implemented a qsys system with a DDR3 controller with uniPHY and a Nios processor (and other cores like PIO,etc..) but i have some problems during the generation process with the Qsys sequencer. The error messages are:Error: s0: Error during execution of "{C:/altera/13.0/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt": child process exited abnormally
Error: s0: Execution of command "{C:/altera/13.0/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt" failed
Error: s0: ]2;Altera Nios II EDS 13.0 C:/altera/13.0/quartus/bin/uniphy_mcc -ac_code sequencer_mc/ac_rom.s -inst_code sequencer_mc/inst_rom.s -ac_rom ../strIV_cycV(4)_altmemddr_0_s0_AC_ROM.hex -inst_rom ../strIV_cycV(4)
_altmemddr_0_s0_inst_ROM.hex -header sequencer/sequencer_auto.h -vheader ../sequencer_auto_h.sv -ac_rom_init sequencer/sequencer_auto_ac_init.c -inst_rom_init sequencer/sequencer_auto_inst_init.c -DAC_ROM_MR0=0010000110001 -
DAC_ROM_MR0_CALIB= -DAC_ROM_MR0_DLL_RESET=0010100110000 -DAC_ROM_MR1=0000001000100 -DAC_ROM_MR1_OCD_ENABLE= -DAC_ROM_MR2=0000000001000 -DAC_ROM_MR3=0000000000000 -DAC_ROM_MR0_MIRR=0010001001001 -DAC_ROM_MR0_DLL_RESET_MIRR=0010011001000
-DAC_ROM_MR1_MIRR=0000000100100 -DAC_ROM_MR2_MIRR=0000000010000 -DAC_ROM_MR3_MIRR=0000000000000 -DQUARTER_RATE=0 -DHALF_RATE=1 -DFULL_RATE=0 -DGUARANTEED_READ_BRINGUP_TEST=0 -DMEM_ADDR_WIDTH=13 -DHARD_PHY=0
Error: s0: child process exited abnormally
Error: s0: Cannot find sequencer/sequencer.elf
Error: s0: An error occurred
while executing
"error "An error occurred""
(procedure "_error" line 8)
invoked from within
"_error "Cannot find $seq_file""
("if" then script line 2)
invoked from within
"if { == 0} {
(procedure "alt_mem_if::util::seq_mem_size::get_max_memory_usage" line 14)
invoked from within
"alt_mem_if::util::seq_mem_size::get_max_memory_usage ]"
invoked from within
"if { !$do_only_rw_mgr_mc && !($bfm_mode || $hps_mode)} {
set calc_mem_size > 0} {
set seq_mem_size "
(procedure "alt_mem_if::gen::uniphy_gen::generate_sequencer_files" line 3)
invoked from within
"alt_mem_if::gen::uniphy_gen::generate_sequencer_files $name "DDR3" $tmpdir QUARTUS_SYNTH"
invoked from within
"foreach generated_file {
set file_name [file tail $genera..."
(procedure "generate_synth" line 8)
invoked from within
"generate_synth strIV_cycV(4)_altmemddr_0_s0"
Info: s0: "altmemddr_0" instantiated altera_mem_if_ddr3_qseq "s0" ---IL PROBLEMA è QUANDO GENERA QUESTO altera_mem_if_ddr3_qseq "s0" (CHE COS'E?)è il sequencer..
Error: Generation stopped, 6 or more modules remaining
Error: ip-generate failed with exit code 1: 7 Errors, 0 Warnings Is there anyone who can help me? Regards. Luca4 Replies
Hi Luca,
Could you post a screenshot of your Qsys connections, specially those for the DDR3 ? Did you try to work with another version of Quartus ? Ddi your Qsys sequencer work well before adding DDR3 controller ? - Altera_Forum
i have kind of the same problem. Maybe you could help me too? I work with the DBC5CEFA7 development board which include a Cyclone V FPGA and an already ready-to-go Nios II cpu. This cpu is embedded in a Quartus project and everything works fine. When i try to complie the unmodified i get the following error message. I dont really know what Qsys is missing here. The system is using two preset files for the DDR3 chips. The temp var is set to a local problem so thats not the case like in http://www.altera.com/support/kdb/solutions/rd02192013_986.html (http://www.altera.com/support/kdb/solutions/rd02192013_986.html) I also post a screenshot of my nios system.
https://www.alteraforum.com/forum/attachment.php?attachmentid=8571 Happy for any advice Cheers TimError: s0: Error during execution of "{C:/program files/quartus/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt": child process exited abnormally Error: s0: Execution of command "{C:/program files/quartus/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt" failed Error: s0: ]2;Altera Nios II EDS 13.0 C:/program files/quartus/quartus/bin/uniphy_mcc -ac_code sequencer_mc/ac_rom.s -inst_code sequencer_mc/inst_rom.s -ac_rom ../nios_cpu_mem_if_ddr3_emif_h_s0_AC_ROM.hex -inst_rom ../nios_cpu_mem_if_ddr3_emif_h_s0_inst_ROM.hex -header sequencer/sequencer_auto.h -vheader ../sequencer_auto_h.sv -ac_rom_init sequencer/sequencer_auto_ac_init.c -inst_rom_init sequencer/sequencer_auto_inst_init.c -DAC_ROM_MR0=0001000100001 -DAC_ROM_MR0_CALIB= -DAC_ROM_MR0_DLL_RESET=0001100100000 -DAC_ROM_MR1=0000000000000 -DAC_ROM_MR1_OCD_ENABLE= -DAC_ROM_MR2=0000000000000 -DAC_ROM_MR3=0000000000000 -DAC_ROM_MR0_MIRR=0001001000001 -DAC_ROM_MR0_DLL_RESET_MIRR=0001011000000 -DAC_ROM_MR1_MIRR=0000000000000 -DAC_ROM_MR2_MIRR=0000000000000 -DAC_ROM_MR3_MIRR=0000000000000 -DQUARTER_RATE=0 -DHALF_RATE=0 -DFULL_RATE=1 -DGUARANTEED_READ_BRINGUP_TEST=0 -DMEM_ADDR_WIDTH=13 -DHARD_PHY=1 Error: s0: UniPHY Sequencer Microcode Compiler Error: s0: Copyright (C) 1991-2010 Altera Corporation Error: s0: Info: Reading sequencer_mc/ac_rom.s ... Error: s0: Info: Reading sequencer_mc/inst_rom.s ... Error: s0: Info: Writing ../nios_cpu_mem_if_ddr3_emif_h_s0_AC_ROM.hex ... Error: s0: Info: Writing ../nios_cpu_mem_if_ddr3_emif_h_s0_inst_ROM.hex ... Error: s0: Info: Writing sequencer/sequencer_auto_ac_init.c ... Error: s0: Info: Writing sequencer/sequencer_auto_inst_init.c ... Error: s0: Info: Writing sequencer/sequencer_auto.h ... Error: s0: Info: Writing sequencer/sequencer_auto.h ... Error: s0: Info: Writing ../sequencer_auto_h.sv ... Error: s0: Info: Microcode compilation successful Error: s0: C:/program files/quartus/quartus/../nios2eds/sdk2/bin/nios2-bsp hal sequencer_bsp .. --default_sections_mapping sequencer_mem --use_bootloader DONT_CHANGE Error: s0: child process exited abnormally Error: s0: Cannot find sequencer/sequencer.elf Error: s0: An error occurred while executing "error "An error occurred"" (procedure "_error" line 8) invoked from within "_error "Cannot find $seq_file"" ("if" then script line 2) invoked from within "if { == 0} { _error "Cannot find $seq_file" }" (procedure "alt_mem_if::util::seq_mem_size::get_max_memory_usage" line 14) invoked from within "alt_mem_if::util::seq_mem_size::get_max_memory_usage ]" ("if" then script line 2) invoked from within "if { !$do_only_rw_mgr_mc && !($bfm_mode || $hps_mode)} { set calc_mem_size > 0} { set seq_mem_size " (procedure "alt_mem_if::gen::uniphy_gen::generate_sequencer_files" line 3) invoked from within "alt_mem_if::gen::uniphy_gen::generate_sequencer_files $name "DDR3" $tmpdir QUARTUS_SYNTH" invoked from within "foreach generated_file { set file_name [file tail $genera..." (procedure "generate_synth" line 8) invoked from within "generate_synth nios_cpu_mem_if_ddr3_emif_h_s0" Info: s0: "mem_if_ddr3_emif_h" instantiated altera_mem_if_ddr3_qseq "s0" Error: Generation stopped, 37 or more modules remaining Info: nios_cpu: Done nios_cpu" with 67 modules, 414 files, 9592561 bytes Error: ip-generate failed with exit code 1: 20 Errors, 6 Warnings Info: Finished: Create HDL design files for synthesis - Altera_Forum
I also tried to put the Qsys working folder directly under my working folder and i have no special chars nor blanks, but i still get the same error.
I solved my problem by updating my Quartus II software from version 13.0 to 13.1.
Now i am able to compile my hardware system.
