17 years agoDDR3 on the Stratix III memory board
Hello I am new to Stratix III. I been trying to create a simple DDR3 Altmemphy test program for the Altera Stratix III memory board. Using the AN436 example as a guide I have a program compil...
17 years agoWell I don't know exactly what is going on but these are my first suspicions:
1 - A damaged board. 2 - A defective or degraded Byte Blaster 3 - Borderline JTAG timing between the Byte Blaster and S3 board. Maybe they just never tested the two together. If the USB-Blaster doesn't fix it then I would seriously consider that the board has some problem or I would start to call into question the design of the JTAG on the board. One thing you can try doing is probing the JTAG data lines with a scope and make sure they look correct. In fact sometimes just adding some capacitance to the signals (like a scope probe) can make things start working. Jake
