17 years agoDDR3 on the Stratix III memory board
Hello I am new to Stratix III. I been trying to create a simple DDR3 Altmemphy test program for the Altera Stratix III memory board. Using the AN436 example as a guide I have a program compil...
17 years agoSorry for not being clear.
The S3 memory board has two jtag connector. One for the Stratix III and another for the Max II. I can connect my byte blaster II to the JTAG port of the Max II and I could detect the MaxII and program it. But when I connect it to Stratix III, I don't see S3 on the Jtag chain. I have to run the Altera S3 memory board software which load NIOS on the the chip before I see the Stratix III on the JTAG chain. But at this point, when I try to use my byte blaster II to program the device, I get halfway there then I get an error: Error: Can't access JTAG chain Error: Can't configure device. Expected JTAG ID code 0x021020DD for device 1, but found JTAG ID code 0xFFFFFFFF. I don't see how the JTAG would be turned off since there is only one device on the chain. Thank you for helping. Victor
