ramsoffer_123
3 years agoddr3 Micron presets
hi Everyone, Im working with CYCLONE V FPGA. we want to combine ddr3 in our design. my question is about the presets in the mega wizard ip. our board design chose ddr3 component part number: MT41K...
AdzimZM_Altera
3 years agoHi Ram,
1) the question is if there is a difference between the components in configuration?
in internal routing? or something else that i am missing.
- This preset will help to fill up the memory configuration in the IP that related to memory device.
2)also what is the difference between HA and JT?
- This marking is referring to FBGA package. You need to refer to memory datasheet for the details.
- You can check this link for the memory datasheet: https://media-www.micron.com/-/media/client/global/documents/products/data-sheet/dram/ddr3/2gb_1_35v_ddr3l.pdf?rev=4a2dca2a48b042fc92188aad62656cec
3)if i will load the configuration of MT41J128M16HA-125 preset on the MT41K128M16JT-125 IT:K TR component it is ok?
- It's better to confirm the memory configuration with the memory datasheet first.
- Can get it here as well: https://www.micron.com/products/dram/ddr3-sdram/part-catalog/mt41k128m16jt-125
Adzim
