ramsoffer_123
3 years agoddr3 Micron presets
hi Everyone, Im working with CYCLONE V FPGA. we want to combine ddr3 in our design. my question is about the presets in the mega wizard ip. our board design chose ddr3 component part number: MT41K...
sstrell
3 years agoYou'd probably need to check the data sheets from Micron to find the differences. I wouldn't use a preset that's for a specific device without confirming in the device's datasheet that the presets match up and will work for my different device.
Perhaps you can use the preset as a starting point and edit it as needed for your device. You could then save the adjusted parameters as a new preset for future designs.
