12 years agoDDR3 HMC settings
Hi, all I am now working to use two 16bits DDR3 to get a 32bits data width DDR3, my question is how will i to do with the settings of "Number of chip selects" and "Mirror Addressing:1 per chip ...
12 years ago --- Quote Start --- I am now working to use two 16bits DDR3 to get a 32bits data width DDR3, my question is how will i to do with the settings of "Number of chip selects" and "Mirror Addressing:1 per chip select" ? --- Quote End --- Typically you select the 16-bit memory IC from the right-side of the GUI and click "Apply", and then under the "Memory Parameters" tab change the width from 16-bits to 32-bits. Cheers, Dave
