DDR3 accessing through SDRAM controller with Uniphy
Hi DGiar,
I apologize for the delay in response. Please see my reply below:
My questions are:
1) Is my design (at least in theory) correct? Or am I wrong in something?
Ans: Everything seems OK. I don’t see any problem with your design. You are allowed to connect multiple master with one slave but please note that the efficiency will be slightly slow as you are sharing 2 master with one slave.
2) I can only use the "soft memory controller" (because only this mode is supported by my dev kit). Is this a problem?
Ans: No, it’s not the problem. But theoretically, hard memory is faster and have better efficiency than soft controller.
3) Both the MM-master peripherals run at the same clock frequency (150 MHz) but the clock network is not the same, since I cannot give to the Nios input clock the "afi_clk" of the SDRAM controller. Since I cannot modify the SDRAM Avalon slave clock (fixed to the "afi_clk" because of the "soft memory controller"), is there any smart idea to make all the peripherals run at the same clock?
Ans: I don’t understand why you unable to connect the afi_clk to the Nios. Supposedly can. You just need to connect the afi_clk to your Nios clock as shown below. Please correct me if I misunderstood your question.
Regarding the waitrequest_n signal, when you send instruction to your slave to perform read/write, at some moment the waitrequest_n signal will deassert for a while until the slave is ready to perform read/write again. Based on the oscilloscope screenshot, I can see the waitrequest_n signal is toggling correctly and I don’t see any stuck at 0 for too long.
NAli1
