16 years agoddr2 problem in quartus 10.0
Hi all. I am still working on a very simple video pipeline, and still I have lots of trouble. I picked up the video example (.qar) of the an427, and compiling it in old quartus (9.1 sp2) It work...
16 years agoFor a simple test of the DDR2 memory, you don't absolutely have to add a clock adapter. SOPC builder will add automatic clock domain crossing logic if needed. Although, the automatic logic is inefficient and slow.
If you really want to give the DDR2 memory a work out, you really should use a DMA component. Although, for your purposes even a simple test is probably good enough. Even if the memory is partially flaky, you should still get something other than a black output from the frame buffer. I doubt the 64 bit Windows 7 is the issue. I have used almost every Web Edition of Quartus since 8.0 on Vista 64 bit without issue.
