14 years agoDDR2 pin assignment
This is a very long shot, probably nobody will answer this, but here I go just in case. In Quartus II 11.1, for an EP4CGX50CF23C7 (F484 package, speed grade 7), I instantiated an altmemphy int...
14 years agoSo far in the SR the information that I have received is:
--- Quote Start --- We don't have the accessibility to disable the software check for the legality of these pin assignment. This Quartus II is develop by the engineering team. Unless a special patch is design for special case but this will have to go into special request. --- Quote End --- I am now inquiring if the interface is still useable, if the pins are assigned in a way that Quartus lets the compile go through, since altmemphy does some initialization and calibration when it starts. The idea is that the pins that were routed properly will still work, provided the DMs are stuck to low.
