14 years agoDDR2 pin assignment
This is a very long shot, probably nobody will answer this, but here I go just in case. In Quartus II 11.1, for an EP4CGX50CF23C7 (F484 package, speed grade 7), I instantiated an altmemphy int...
14 years agoddr pins work with the other ddr pins.
it should be assigned with same group of dq-pins and dqs pins. however, if you want to know which location should be good for your system. remove pin assignment and compile the project. and use back-annotate. it automatically assign certain pin. and you can change your schematic..... if it is not done yet. you can write ddr logic by yourself.( that is tough stuff ) if your schematic is done, you can find another way to fix the problem.
