15 years agoDDR PIN placement error
Hi all, I use a Cyclone IV E EP4CE40F23C8 with Quartus 11.0 I have this error message when i try to place ddr pins --- Quote Start --- Error: altmemphy pin placement was...
15 years ago --- Quote Start --- Another question : have you any recommendation for flash memory pinout? I use Spansion S29GL512N it dosen't work also :( (you can find the project archive to test flash here) --- Quote End --- The flash interface can use any compatible I/O pins. Did you simulate your design with the Spansion flash model, or at least simulate it with a simple memory model and check that you have the read/write timing correct? I've used the Spansion flash on many boards, without issues. Eg., see the timing on p30 http://www.ovro.caltech.edu/~dwh/carma_board/fpga_configuration.pdf Cheers, Dave
