GOMEZ_IT
4 years agoDDR MT46V16M16P-5B on cycloneIV EP4CE6
Good morning.
I would like to use a Micron MT46V16M16TG-6T model sdram on an intel cycloneIV ep4ce6e22c8 144-pin EQFP.
This DDR SDRAM is included in the "DDR High Performance Controller v18.1" megawi...
- 4 years ago
Hi Luca,
Yes you can set the "Total Memory interface DQ width" to 16 bits and disable the "Drive DM pins from FPGA" option.
I hope you can understand the memory parameter setting.
Do let me know if you have any further question on this thread.
Adzim
AdzimZM_Altera
4 years agoHi Luca,
In my previous reply, the parameter can be found as snapshot below.
Then you will have one DQ group only.
If the "Drive DM pins for FPGA" is set to no, then you're not using the DM pin in the design.
You will have a x8 DQ group in the design.
Adzim
- GOMEZ_IT4 years ago
OK understood. But in case you say I am forced to work with 8 bits on the ram, and not with 16 bits. Is there any way to work at 16bit DQ and not use the 2 bit DM (data mask)?
