DDR MT46V16M16P-5B on cycloneIV EP4CE6
- 4 years ago
Hi Luca,
Yes you can set the "Total Memory interface DQ width" to 16 bits and disable the "Drive DM pins from FPGA" option.
I hope you can understand the memory parameter setting.
Do let me know if you have any further question on this thread.
Adzim
Hi Luca,
Thank you for submitting your question in Intel Community.
I'm Adzim from Penang Global Application Engineer.
I will assist you in this thread.
The DM pin is required when writing to DDR2 and DDR SDRAM devices.
You may set the DQ width of 8 by modifying the parameter of memory preset in the IP GUI.
Adzim
Thanks for the reply.
Now i write this reply with my second Intel account (LMelo2).
The setting you suggest is actually the one already present by default.
However, the megawizard has another setting, "DRIVE DM PIN FOR FGA".
But if set "NO" this option, the DM pins [1: 0] are not generated.
In this case is it sufficient to connect the DMs directly on the DDR to '0'?
