GLees
Contributor
3 years agoDDIO Input Speed Cyclone V vs. Cyclone 10GX
When I create a simple DDIO input for both the Cyclone V and Cyclone 10GX parts, the Cyclone V has an Fmax about twice the Cyclone 10GX.
Cyclone V, Fmax ~ 400Mhz
Cyclone 10GX, Fmax < 200...
AdzimZM_Altera
3 years agoHi Greg,
Why you do not use EMIF IP for Cyclone 10 GX device?
You can get higher data rate because it's a hard IP for DDR memory standard.
Adzim
- GLees3 years ago
Contributor
I guess due to my own ignorance. I assumed "EMIF IP" was for external memory interfaces. As I explained, I want to design a deserializer. Is the EMIF IP general-purpose enough for me to use it for a deserializer? I need 8 channels, 64 bits each, 350Mhz DDR clock.
