17 years agodcfifo timing details
I am trying to find out some timing info of dcfifo, but couldn't find it anywhere. The "Single- and Dual-Clock FIFO Megafunction User Guide" talks about the flag latency, but failed to disclose which...
17 years agoSynthesis the FIFO by itself and launch the RTL viewer(or just dive down to it from your full design). The actual synthesized nodes are a pain and so the combinatorial names in TimeQuest won't help, but the RTL viewer should be good enough to give a sense of what's going on, specifically when you see sub-hierarchies with names like gray2bin. Just push down into the FIFO, and use right-click to filter from/to things you've highlighted. It's not going to give exact details, but enough to know where the pipelines are at, what's being compared, etc.
