17 years agodcfifo timing details
I am trying to find out some timing info of dcfifo, but couldn't find it anywhere. The "Single- and Dual-Clock FIFO Megafunction User Guide" talks about the flag latency, but failed to disclose which...
17 years agoI've actually never seen that request before, but can see how it would help your application(and someone else chimed in they've seen this). I'll see what I can do to get someone to look at it. My concern is that, in your application, I don't think what you have would meet timing anyway. Note that "write_ptr_synced_in_rdclk" is a gray coded value. You can't do simple math with a gray code(at least carry-chain math), so you need to either convert it back to binary or go through a large decode just to do that first line. So even if it were made to work in 1 clock(and at first glance it looks all right, but I haven't really dissected it) I doubt it would make timing.
To get a better idea of what's going on, go to the RTL viewer. The behaviour is pretty understandable. Note that the combinatorial output for rdusedwd is just a single adder, which should be able to use the carry chain. If that can't meet timing in your design, I What are your read and write clock frequencies? I'm trying to think of another way, and that might help.
