17 years agoDCFIFO and external syncronizer
hi, i'm new to ASIC design. i'm using megaWizard DCFIFO to send the data from two different clock domain. I'm designing network adapter in Network-on-chip. i want to use the DCFIFO to pu...
17 years ago --- Quote Start --- No. The whole point of the DCFIFO is to take care of the synchronization for you. --- Quote End --- so, the flow will be like this : --> 4 flits (16 bits each) send to router NA domain(100Mhz) Router domain (200Mhz) data_in[16bit][3:0] ---------> data_out[16bit][3:0] signals & data synchronization process is taken care by DCFIFO. correct? thanks Guru..:)
