12 years agoDC-Coupling LVDS Tx to PCML Rx (Cyclone IV GX)
I want to use a Cyclone IV transceiver input to receive a LVDS signal (about 800Mbps over 50cm cable). I need to use DC-coupling as the signal is not DC balanced. Because of the Vcm requirement...
12 years ago --- Quote Start --- I think when I connect the SY54016AR (with Vcco of 1.2V) to the FGPA (either with external termination to 1.2V or using the internal termination of the FPGA), I will not achieve this required Vcm of 0.82V +/- 10%. --- Quote End --- If you can find a part with Vtt = 1.2V and Vpp = 0.8V, then this would produce Vcm = 1.2V - 0.8V/2 = 0.8V, which is within 10% of Vcm. For example, the AD9956 AgileRF has a CML/PECL output driver that does not include resistors. On that part you can program the constant current, so with a 50-ohm termination at the FPGA, you could program an output current of (1.2V - 0.82V)/50-ohm = 7.6mA, and have the correct Vcm. I realize that this Analog Devices part is not suitable for your application, but it does show you that parts with programmable output voltage swing exist, and now you just have to find one :) Cheers, Dave
