8 years agoDC coupled ADC (HSMC)
I bought a "Terasic Cyclone V GX Starter Kit" and I have to process a analog signal. I bought a "Terasic Highspeed AD/DA Card" and connected it via HSMC. Unfortunatly I realized that the inputs are t...
8 years ago --- Quote Start --- See this previous threads http://www.alteraforum.com/forum/showthread.php?t=39308 http://www.alteraforum.com/forum/showthread.php?t=3304 I posted a simple schematic bypassing the transformers, achieving a 0.5 to 2.5 V DC input range. --- Quote End --- Thank you for the answer. And happy new year BTW. I browsed the manual of the AD and not really understood how the 0.5 to 2.5 V range is resulting for the board in combination with your adaptions. Could you please explain where this range is coming from? And is there a way to change it to 0-2V? Additionally I have an differental signal coming via the SMA connector. On an oscilloscope I can see the signal moves between 0 and 2V. Is there any way to use this differential signal?
