12 years agoDATA0 pin in Cyclone IV E
I'm confused on the function of "DATA0" pin in EP4CE10.
On page 3 of "Cyclone IV Pin Connection Guidelines.pdf" from Altera, it says DATA0 pin is "a dedicated configuration data input pin". So, if it's a dedicated configuration pin, it can not be used as user I/O. But, in other document, it seems this pin can be used as user i/o after configuration. In my design, AS mode is used to configure FPGA from a SPI flash. After configuration, I want to use "DATA0" pin for other purpose. Can I use this pin in my own logic? "Cyclone IV Pin Connection Guidelines.pdf " is attached.2 Replies
Can somebody give some hints?
in your attached file,i found this description:"After AS configuration, DATA0 is a dedicated input pin with optional user control."
From what i understand,after AS configuration,DATA0 can only be used as input port.
