12 years agoData Transmission Using RJ45 Cable between dev board and laptop
Hi I'm totally a beginner and my question may seem a little bit stupid, but I would be grateful if you provide any help. I want to transmit data between my laptop and a Stratix IV GX Developm...
12 years agoThanks for your reply, I downloaded design files for my board, but ran into problems. (Actually I couldn't find any manual on how to use the design files, so I decided to figure it out myself)
I tried to compile the project, but compilation failed. Then I tried to generate the Qsys files suspecting maybe those are not generated. The peripheral Qsys generated successfully, but the ethernet_system failed because the component "tse_mac" was not found. Can you help me through using this example please? Thanks
