8 years agoData from FPGA to Ethernet
Hello All, I followed an ethernet tutorial, but there it uses on-chip memory with 2 SGDMA. In this, I think I can send data from Nios to ethernet and ethernet to Nios. But I would like to send...
8 years agoThank you for your reply.
It is data acquisition system from a camera. The Camera gets 15 frames per second with 600 * 800 pixels. Each pixel is 8 bit and I want to transfer this pixel to the PC via ethernet. will this system will work for this system? Do I have made them in the form of frames or it will handle via NIOS? It will be helpful if there are any example projects available. Thank you in advance.
