15 years agoData between gated clk's
Hi, I have a design that needs to use gated clk's in order to reduce the power consumption. I try to avoid using any speciel cells or PLL's, because I'm going to port it to an ASIC later on - but ...
15 years agoThank you for your reply. I'm actually very glad you can see the purpose :) I thought I would be able to make the 2 clk's similar in time, but as I understand it changes the hold time for the data signals instead.
Thx again.
